How to manage partitions
You can manipulate storage partitions via the MAAS CLI. Note that partitions cannot be managed through the MAAS UI.
List partitions
        "bootable": false,
        "id": 9,
        "resource_uri":
"/MAAS/api/2.0/nodes/4y3h8a/blockdevices/10/partition/9",
        "size": 5360320512,
        "type": "partition",
        "filesystem": {
            "mount_options": null,
            "label": null,
            "fstype": "lvm-pv",
            "mount_point": null
Create partition
    "bootable": false,
    "filesystem": null,
    "used_for": "Unused",
    "id": 10,
    "size": 5360320512,
Delete partition
Format partition
    "id": 9,
    "size": 5360320512,
    "bootable": false,
    "filesystem": {
        "mount_point": null,
        "fstype": "ext4",
        "label": "
Unformat partition
    "bootable": false,
    "filesystem": null,
    "id": 10,
    "size": 5360320512,
Mount partition
    "bootable": false,
    "id": 10,
    "size": 5360320512,
    "filesystem": {
        "mount_options": ",
        "label": ",
        "fstype": "ext4",
        "mount_point": "/srv"
Unmount partition
    "bootable": false,
    "id": 10,
    "size": 5360320512,
    "filesystem": {
        "label": ",
        "fstype": "ext4",
        "mount_point": null
    "id": 3,
    "size": 2000003072
