You can create a custom ESXi image. MAAS cannot directly deploy the VMware ESXi ISO; a specialised image must be created from the ISO. Canonical has created a Packer template to automatically do this for you; this page explains how to use it.
Verify requirements
VMware ESXi has a specific set of requirements and limitations which are more stringent than MAAS.
Basic requirements
The machine building the deployment image must be a GNU/Linux host with a dual core x86_64 processor supporting hardware virtualisation with at least 4GB of RAM and 10GB of disk space available. Additionally the qemu-kvm and qemu-utils packages must be installed on the build system.
libvirt testing
While VMware ESXi does not support running in any virtual machine it is possible to deploy to one. The libvirt machine must be a KVM instance with at least CPU 2 cores and 4GB of RAM. To give VMware ESXi access to hardware virtualisation go into machine settings, CPUs, and select ‘copy host CPU configuration.’
VMware ESXi has no support for libvirt drivers. Instead an emulated IDE disk and an emulated e1000 NIC must be used.
Storage limitations
Only data stores may be configured using the devices available on the system. The first 9 partitions of the disk are reserved for VMware ESXi operating system usage.
WARNING: VMware does not support cloning boot devices - you may run into issues triggered by non-unique UUID. This may lead to data corruption on VMFS data stores when using cloned boot devices.
Network limitations
Bridges are not supported in VMware ESXi. In addition, certain MAAS bond modes are mapped to VMware ESXi NIC team sharing with load balancing, as follows:
- balance-rr - portid
- active-backup - explicit
- 802.3ad - iphash, LACP rate and XMIT hash policy settings are ignored.
No other bond modes are currently supported.
WARNING: VMware ESXi does not allow VMs to use a PortGroup that has a VMK attached to it. All configured devices will have a VMK attached. To use a vSwitch with VMs you must leave a device or alias unconfigured in MAAS.
qemu-nbd error
If the image fails to build due to a qemu-nbd
error, try disconnecting the device with:
$ sudo qemu-nbd -d /dev/nbd4
Prerequisites
- A machine running Ubuntu 18.04+ with the ability to run KVM virtual machines.
- qemu-utils
- Python Pip
- Packer
- The VMware ESXi installation ISO must be downloaded manually^.
- MAAS 2.5 or above, MAAS 2.6 required for storage configuration
Install packer
Packer is easily installed from its Debian package:
sudo apt install packer
This should install with no additional prompts.
Install dependencies
sudo apt install qemu-utils
Install Python pip
sudo apt install pip
Get the templates
You can obtain the packer templates by cloning the packer-maas github repository^, like this:
git clone https://github.com/canonical/packer-maas.git
Make sure to pay attention to where the repository is cloned. This package should install with no additional prompts.
Locate ESXi
The appropriate packer template can be found in the subdirectory vmware-esxi
in the packer repository.
Customise the image
The deployment image may be customized by modifying packer-maas/vmware-esxi/KS.CFG
Build the image
Build ESXi
You can easily build the image using the Makefile:
$ make ISO=/path/to/VMware-VMvisor-Installer-6.7.0.update03-14320388.x86_64.iso
OR run manually
Alternatively, you can manually run packer. Your current working directory must be in packer-maas/vmware-esxi
, where this file is located. Once in packer-maas/vmware-esxi
, you can generate an image with:
$ sudo PACKER_LOG=1 packer build -var 'vmware_esxi_iso_path=/path/to/VMware-VMvisor-Installer-6.7.0.update03-14320388.x86_64.iso' vmware-esxi.json
vmware-esxi.json
is configured to run Packer in headless mode. Only packer output will be seen. If you wish to see the installation output, connect to the VNC port given in the packer output, or remove the line containing “headless” in vmware-esxi.json
Installation is non-interactive.
Upload to MAAS
You can upload the ESXi image to MAAS with the following command:
$ maas $PROFILE boot-resources create name='esxi/6.7' title='VMware ESXi 6.7' architecture='amd64/generic' filetype='ddgz' content@=vmware-esxi.dd.gz
