*Errors or typos? Topics missing? Hard to read? Let us know.
This page describes machine storage operations that are common to all layouts and storage types.
Set default layout
All machines will have a default layout applied when commissioned. If you change the default layout, that new default will only apply to newly-commissioned machines. To set the default storage layout for all machines:
In the MAAS UI, choose Settings > Storage > choose default layout. A default erasure configuration can be also set by selecting Storage > Settings. If option Erase machines’ disks prior to releasing is chosen, then users will be compelled to use disk erasure. That option will be pre-filled in the machine’s view and the user will be unable to remove the option.
Via the MAAS UI, use the following commands:
Set per-machine layout (CLI)
An administrator can set a storage layout for a ‘Ready’ machine:
You must specify all storage sizes in bytes. This action will remove the configuration that may exist on any block device.
Erase disks (CLI)
and not:
Note the difference in singular and plural “machine/machines” in the commands. Releasing a machine requires that you have the system_id
of the machine to be released, which you can obtain with a command like this one:
Parameters secure_erase
and quick_erase
are both optional, although if you don’t specify either of them, the entire disk will be overwritten with null bytes. Note that this overwrite process is very slow.
Set conditional erasure (CLI)
