Reference: MAAS metrics
This page provides a MAAS metrics reference, categorised into two sections: “Cluster metrics” and “Performance metrics.”
Cluster metrics
maas_machines
The number of machines known by MAAS, by status
  • Type: Gauge
  • Unit: Count of machines
  • Labels
    Label Description
    maas_id MAAS cluster UUID
    status machine status
maas_nodes
Number of nodes known by MAAS per type (machine, device or controller)
  • Type: Gauge
  • Labels
    Label Description
    type type of node (machine/device/controller)
maas_net_spaces
Number of network spaces
  • Type: Gauge
  • Unit: Count of spaces
  • Labels
    Label Description
maas_net_fabrics
Number of network fabrics
  • Type: Gauge
  • Unit: Count of fabrics
  • Labels
    Label Description
maas_net_vlans
Number of network VLANs
  • Type: Gauge
  • Unit: Count of vlans
  • Labels
    Label Description
maas_net_subnets_v4
Number of IPv4 subnets
  • Type: Gauge
  • Unit: Count ipv4 subnets
  • Labels
    Label Description
maas_net_subnets_v6
Number of IPv6 subnets
  • Type: Gauge
  • Unit: Count of ipv6 subnets
  • Labels
    Label Description
maas_net_subnet_ip_count
Number of IPs in a subnet by status
  • Type: Gauge
  • Unit: Count of ips
  • Labels
    Label Description
    status available or used
maas_net_subnet_ip_dynamic
Number of used dynamic IPs in a subnet
  • Type: Gauge
  • Unit: Count of used dynamic ips
  • Labels
    Label Description
    cidr subnet address
maas_net_subnet_ip_reserved
Number of used reserved IPs in a subnet
  • Type: Gauge
  • Unit: Count of used reserved ips
  • Labels
    Label Description
    cidr subnet address
maas_net_subnet_ip_static
Number of used static IPs in a subnet
  • Type: Gauge
  • Unit: Count of used static ips
  • Labels
    Label Description
    cidr subnet address
maas_machines_total_mem
Amount of combined memory for all machines
  • Type: Gauge
  • Unit: Megabytes of memory
  • Labels
    Label Description
maas_machines_total_cpu
Amount of combined CPU counts for all machines
  • Type: Gauge
  • Unit: Count of cpus
  • Labels
    Label Description
maas_machines_total_storage
Amount of combined storage space for all machines
  • Type: Gauge
  • Unit: Bytes of storage
  • Labels
    Label Description
maas_kvm_pods
Number of KVM hosts
  • Type: Gauge
  • Unit: Count of kvm hosts
  • Labels
    Label Description
maas_kvm_machines
Number of virtual machines allocated in KVM hosts
  • Type: Gauge
  • Unit: Count of virtual machines
  • Labels
    Label Description
maas_kvm_cores
Total number of CPU cores present on KVM hosts
  • Type: Gauge
  • Unit: Count of kvm cores
  • Labels
    Label Description
maas_kvm_memory
Total amount of RAM present on KVM hosts
  • Type: Gauge
  • Labels
    Label Description
maas_kvm_storage
Total amount of storage space present on KVM hosts
  • Type: Gauge
  • Labels
    Label Description
maas_kvm_overcommit_cores
Total number of CPU cores present on KVM hosts adjusted by the overcommit setting
  • Type: Gauge
  • Unit: Overcommitted number of cores
  • Labels
    Label Description
maas_kvm_overcommit_memory
Total amount of RAM present on KVM hosts adjusted by the overcommit setting
  • Type: Gauge
  • Unit: Overcommitted megabytes of memory
  • Labels
    Label Description
maas_machine_arches
Total number of machines per architecture
  • Type: Gauge
  • Labels
    Label Description
    arch machine architecture
maas_custom_static_images_uploaded
Number of custom OS images present in MAAS
  • Type: Gauge
  • Unit: Count of images
  • Labels
    Label Description
    base_image custom image base OS
    file_type image file type
maas_custom_static_images_deployed
Number deployed machines running custom OS images
  • Type: Gauge
  • Labels
    Label Description
maas_vmcluster_projects
Number of KVM clusters
  • Type: Gauge
  • Unit: Count of projects
  • Labels
    Label Description
maas_vmcluster_hosts
Total number of KVM hosts in clusters
  • Type: Gauge
  • Unit: Count of vm hosts
  • Labels
    Label Description
maas_vmcluster_vms
Total number of virtual machines in KVM clusters
  • Type: Gauge
  • Labels
    Label Description
Performance metrics
maas_http_request_latency
The time MAAS takes to process a REST API call. It doesn’t include any time associated with network, including proxy processing
  • Type: Histogram
  • Unit: Seconds
  • Labels
    Label Description
    host controller IP address
    method HTTP method
    op REST API operation name
    path REST API endpoint
    status HTTP response status code
maas_http_response_size
The size of REST API responses
  • Type: Histogram
  • Unit: Bytes
  • Labels
    Label Description
    method HTTP method
maas_http_request_query_count
The number of database operations executed per REST API call
  • Type: Histogram
  • Unit: None
  • Labels
    Label Description
    method HTTP method
maas_http_request_query_latency
The time required to perform a single database operation during a REST API call. The database latency is measured from the moment MAAS starts a transaction until it gets the response
  • Type: Histogram
  • Unit: Seconds
  • Labels
    Label Description
    method HTTP method
maas_rack_region_rpc_call_latency
The time a Region controller takes to perform a RPC call to a Rack controller. The latency is measured from the request to the response.
  • Type: Histogram
  • Unit: Seconds
  • Labels
    Label Description
    call RPC operation
maas_region_rack_rpc_call_latency
The time a Rack controller takes to perform a RPC call to a Region controller. The latency is measured from the request to the response.
  • Type: Histogram
  • Unit: Seconds
  • Labels
    Label Description
    call RPC operation
maas_websocket_call_query_count
The number of database operations executed per WebSocket call
  • Type: Histogram
  • Unit: None
  • Labels
    Label Description
    call WS operation
maas_websocket_call_query_latency
The time required to perform a single database operation during a WebSocket call. The database latency is measured from the moment MAAS starts a transaction until it gets the response
  • Type: Histogram
  • Unit: Seconds
  • Labels
    Label Description
    call WS operation
maas_websocket_call_latency
The time MAAS takes to process a WebSocket call. It doesn’t include any time associated with network, including proxy processing
  • Type: Histogram
  • Unit: Seconds
  • Labels
    Label Description
    call WS operation
maas_dns_update_latency
The time MAAS takes to setup all zones in the DNS service per update type, which can be ‘reload’ (cold-start) or ‘dynamic’ (RNDC operation)
  • Type: Histogram
  • Unit: Seconds
  • Labels
    Label Description
    update_type reload or dynamic
maas_dns_full_zonefile_write_count
Count of full DNS zone rewrite operations
  • Type: Counter
  • Unit: None
  • Labels
    Label Description
    zone DNS zone name
maas_dns_dynamic_update_count
Count of dynamic DNS zone update operations
  • Type: Counter
  • Unit: None
  • Labels
    Label Description
    zone DNS zone name
maas_rpc_pool_exhaustion_count
number of occurrences of the RPC connection pool allocate its maximum number of connections
  • Type: Counter
  • Unit: None
  • Labels
    Label Description
maas_lxd_fetch_machine_failure
Total number of failures for fetching LXD machines
  • Type: Counter
  • Unit: None
  • Labels
    Label Description
maas_lxd_disk_creation_failure
Total number of failures of LXD disk creation
  • Type: Counter
  • Unit: None
  • Labels
    Label Description
maas_virsh_storage_pool_creation_failure
Total number of failures of virsh storage pool creation
  • Type: Counter
  • Unit: None
  • Labels
    Label Description
maas_virsh_fetch_mac_failure
Total number of failures of virsh interfaces enumeration
  • Type: Counter
  • Unit: None
  • Labels
    Label Description
maas_virsh_fetch_description_failure
Total number of failures of virsh domain description
  • Type: Counter
  • Unit: None
  • Labels
    Label Description
maas_tftp_file_transfer_latency
Time required to transfer a file to a machine using TFTP
  • Type: Histogram
  • Unit: Seconds
  • Labels
    Label Description
    filename file requested
