Python API client reference (deb/3.0/UI)
The python-libmaas client library is an asyncio-based client library whose purpose is to allow developers, integrators and administrators to better interact with MAAS. This software is in development and does not yet support all MAAS endpoints (nor all operations). It currently supports MAAS versions 2.1 and 2.2-beta3.
Two questions you may have:
  1. What should I know about library endpoints?
  2. How can I install and use python-libmaas?
Library endpoints
At this time, the client library supports these eight endpoints:
  1. account
  2. boot-sources, boot-resources
  3. machines, devices, region controllers, rack controllers
  4. events
  5. configuration
  6. tags
  7. version
  8. zones
There are two resources that will help you better understand the above terms and how they are used:
  1. Concepts and terms
  2. API documentation
Installation and usage of python-libmaas
For installation and initial steps, see these external links:
  1. https://github.com/maas/python-libmaas
  2. http://maas.github.io/python-libmaas/index.html
For examples, see these external links:
  1. http://maas.github.io/python-libmaas/client/index.html
  2. http://maas.github.io/python-libmaas/client/nodes/index.html
For pypi information, see this external link:
https://pypi.python.org/pypi/python-libmaas
