Test logs (deb/3.1/CLI)
Serial Number:    QM00001
Firmware Version: 2.5+
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Unavailable
Write cache is:   Enabled
ATA Security is:  Unavailable
Wt Cache Reorder: Unavailable
General SMART Values:
					was completed without error.
					been run.
					command.
					Self-test supported.
					power-saving mode.
Short self-test routine
Extended self-test routine
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
SMART Error Log Version: 1
No Errors Logged
SCT Commands not supported
