How to set up NTP (deb/3.1/CLI)
The region controller configures the NTP service to keep its time synchronised from one or more external sources. By default, the MAAS region controller uses ntp.ubuntu.com. Rack controllers also configure the NTP service, synchronising their time with the region controllers. Rack controllers also configure DHCP with the correct NTP information. Any machine on the network that obtains a DHCP lease from MA/snap/3AS will benefit from NTP support.
You can specify an external NTP server with two successive commands:
maas $PROFILE maas set-config name=ntp_servers value=$NTP_IP_ADDRESS
followed by:
maas admin maas set-config name=ntp_external_only value=true
