- internal proxy (default)
- external proxy
- no proxy
Configuring a proxy with MAAS consists of enabling/disabling one of the above three options and enabling/disabling proxying on a specific subnet. This article will help you learn:
About the MAAS internal proxy
MAAS manages its proxy. So although the active configuration, located in file /var/snap/maas/current/proxy
, can be inspected, it is not to be hand-edited. The proxy is automatically installed with the MAAS snap.
MAAS manages its proxy. So although the active configuration, located in file /var/lib/maas/maas-proxy.conf
You must install the proxy on the same host as the region controller (via the ‘maas-proxy’ package).
How to create an external proxy
In the web UI, visit the ‘Settings’ page and select the ‘Network services’ tab. The ‘Proxy’ section is at the top. You can apply your changes by pressing the ‘Save’ button.
To enable the internal proxy, ensure that the checkbox adjacent to ‘MAAS Built-in’ is selected. This internal proxy is the default configuration.
To enable an external proxy, activate the ‘External’ checkbox and use the new field that is displayed to define the proxy’s URL (and port if necessary).
An upstream cache peer can be defined by enabling the ‘Peer’ checkbox and entering the external proxy URL into the field. With this enabled, machines will be configured to use the MAAS built-in proxy to download cached APT packages.
To prevent MAAS machines from using a proxy, enable the ‘Don’t use a proxy’ checkbox.
Enabling and disabling proxying, in general, is done via a Boolean option (‘true’ or ‘false’). The following command will disable proxying completely:
maas $PROFILE maas set-config name=enable_http_proxy value=false
To set an external proxy, ensure proxying is enabled (see above) and then define it:
maas $PROFILE maas set-config name=http_proxy value=$EXTERNAL_PROXY
For example,
maas $PROFILE maas set-config name=enable_http_proxy value=true
maas $PROFILE maas set-config name=http_proxy value=http://squid.example.com:3128/
Enabling and disabling proxying per subnet is done via a Boolean option (‘true’ or ‘false’). Here is how you can disable proxying on a per-subnet basis:
maas $PROFILE subnet update $SUBNET_CIDR allow_proxy=false
For example,
maas $PROFILE subnet update 192.168.0.0/22 allow_proxy=false
