Six questions you may have:
- How do I list availability zones?
- How do I add an availability zone?
- How do I edit an existing availability zone?
- How do I delete an existing availability zone?
- How do I assign a machine to an availability zone?
- How do I allocate a machine in a particular zone?
Allocate a machine in a zone
Allocating a machine in a particular zone can only be done via the MAAS CLI.
To deploy in a particular zone, call the acquire
method in the region-controller API <region-controller-api> as before, but pass the zone
parameter with the name of the zone. This method will allocate a machine in that zone, or fail with an HTTP 409 (“conflict”) error if the zone has no machines available that match your request.
Alternatively, you may want to request a machine that is not in a particular zone or one that is not in any of several zones. To do that, specify the not_in_zone
parameter to acquire
. This parameter takes a list of zone names; the allocated machine will not be in any of them. Again, if that leaves no machines available that match your request, the call will return a “conflict” error.
It is possible, though not usually useful, to combine the zone
and not_in_zone
parameters. If your choice for zone
is also present in not_in_zone
, no machine will ever match your request. Or if it’s not, then the not_in_zone
values will not affect the result of the call at all.
