How to manage VM hosts (snap/3.1/CLI)
In order to deploy a VM host in your MAAS network, you first need to set up a bridge to connect between your VM host and MAAS itself. Once that’s done, you can add and manage VM hosts – and subsequently, create VMs to act as MAAS machines. This article explains:
How to set up a VM host bridge with the web UI
Select the machine you want to use as a VM host, switch to the “Network” tab. Select the network where you want to create the bridge and click “Create bridge:”
Then you can deploy Ubuntu.
How to use the MAAS API to configure a bridge
  1. Select the interface you wish to configure the bridge on. This example uses the boot interface, since the boot interface must be connected to a MAAS controlled network – but any interface is allowed:
  2. Create the bridge:
How to set up a VM host bridge with netplan
network:
    bridges:
        br0:
            addresses:
            - 10.0.0.101/24
            gateway4: 10.0.0.1
            interfaces:
            - enp1s0
            macaddress: 52:54:00:39:9d:f9
            mtu: 1500
            nameservers:
                addresses:
                - 10.0.0.2
                search:
                - maas
            parameters:
                forward-delay: 15
                stp: false
    ethernets:
        enp1s0:
            match:
            mtu: 1500
            set-name: enp1s0
        enp2s0:
            match:
                macaddress: 52:54:00:df:87:ac
            mtu: 1500
            set-name: enp2s0
        enp3s0:
            match:
                macaddress: 52:54:00:a7:ac:46
            mtu: 1500
            set-name: enp3s0
    version: 2
How to set up a VM host bridge with libvirt
  1. Disable DHCP on libvirt’s default network, or
  2. Create a new libvirt network maas with DHCP disabled.
cat << EOF > maas.xml
<network>
 <name>maas</name>
 <forward mode='nat'>
   <nat>
   </nat>
 </forward>
 <dns enable="no" />
 <domain name='testnet'/>
 </ip>
</network>
EOF
virsh net-define maas.xml
How to set up SSH for use by libvirt
How to set up SSH (libvirt only)
$ sudo -i
sudo ssh-keygen -f id_rsa
Finally, on the VM host, you’ll need to add id_rsa.pub to the authorized_keys file in /home/<vm-host-user-homedir-name>/.ssh/, where <vm-host-user-homedir-name> is the name of your VM host user.
How to add a VM host
After installing MAAS, the ‘KVM’ page is typically empty:
If you want to add a LXD (or libvirt) KVM host to a machine which is already installed, you can do so with the ‘Add KVM’ button:
How to authenticate LXD VM hosts via certificates
Suppose that you’re creating a new LXD KVM, beginning from the top tab in MAAS:
Select “Add KVM”, which brings you to the definition screen:
From here, you’ll continue by choosing your authentication method.
How to let MAAS create a certificate for you
If you choose “Generate new certificate”, as shown above, you’ll come to a screen like this one:
You can still choose to use the LXD trust password (entered when you ran lxd init during LXD installation). You can also, though, choose to use the certificate MAAS has just generated for you. To do that, select the entire contents of the text box, copy it, and paste it into a terminal window – then hit “Enter”:
$ lxc config trust add - <<EOF
> -----BEGIN CERTIFICATE-----
> MIIErTCCApUCEQCGa86XdjYUGm8h8YOh4HAEMA0GCSqGSIb3DQEBDQUAMAAwHhcN
> MjEwOTI0MjE1NDQ4WhcNMzEwOTIyMjE1NDQ4WjApMScwJQYDVQQDDB5teTBuZXh0
> LTMuMS4wLWJldGExLWt2bUB3YWxkZW4wggIiMA0GCSqGSIb3DQEBAQUAA4ICDwAw
> ggIKAoICAQC1tmJbSYx3Jb5JcuqLvyO6P0RtYWCbjVYOSAIM1PKHZJRvako6QhjR
> 6wWNcVLAjDJIMuEBysrI8mcAv9D/AfT2qLQ/5mg7anbxfrd3YXG2nc70QJazpFaw
> INDc85wrdJD5NEd50iaka+PztIAWzoZWQr/pLb7hUDnArzSHp5J+w0dRCUh54SyW
> Du4mLpDks5UqMeONO1o7lbaQuBdzGtR4btdmvOkJfg/Pu3i/rzFZ1vvn1JhZTX96
> +xH7tJQiqOk0SXG7F2RmbYiYDhAkiysbMoyOHBCf/qFWq4Vtd/VMxOAT1WERrgWn
> 8nL5kRBozV94QocJaOe+GUSWLHsRpsVa8jiAj3LS2CFQfpaEsrzLSlQOeN2rNB9z
> DO9yGXGql4tUpgtyEvxB/zVrIGd04iTC3D4S9b1KyzTbSsyjTc/XJhUStnn49ySW
> Iwv1eHa2jMvIjRVm5sRfpf0EOZW27HLI1AqDOXR0DmlM2mWvndjvfacX+41I8vuG
> +RPq0ZjDhwfRmUaLiebzcExwPmSHAxqiaV+t0n6ivDWTNk6cNc38rZBh3x6I7JMR
> /85Rc1blLSF7QBMA1HxheCUYzBPTKsdE2btygq9vShRXCdSekV0jGoL1g0n6T59r
> +9nHShgc/Bzk42kcddQySlrqWWHrXX6Z2N1R3eYpuvSEaKsnsjqjwwIDAQABMA0G
> CSqGSIb3DQEBDQUAA4ICAQA4d1Xqi941ssyJoiovTzBgMDSp9kqjpB83BRqbF9oZ
> fQGkezn2jF7SnaXbTyR/K+nir5Rms8OZfUxyZJwYh/YCdnIF8hzC32mLJbP6jcJV
> LS0OD+EipwyRLSe9g2it68TtAhhVXKPx3tGQWWiXtJOF631sJRcRUZATc9nco5H2
> 91GKog4LdFeKD3ArOq1GkE9r95WauTV37x0c474XBt2mVcEvFW50oZbIBPaWLt8E
> q8NG0KYkfIHkhXDGqPDkUtdPJlkiGwqXdaqghuG31a4Or9IKcNmDlli47apaWWJW
> /gqZfFALbOrSJHg10PCqNsfoKmQr2YZzPlTjG39RA7sA1XR6y+lQZqwcXnXk2iAE
> n62OkRUrYVXzBo99zk5jQJVEg6zhfPH9zl6Jmn/vBu0p6RqmqNLTTlMOio8VOp9e
> 9Gyb9uRwzwZ9zgydgI4bHMvcIAq+46wTruOfXBNATWLC2YqXbc+9QqemJebcXULW
> Wf7Sc+SHHx2cVb4OUvUD8keZN37No/2vfZ9NI2SJOI4SxlV2yf6ZRyb7MYIwpm1h
> YTzyS+ywUN4C8p1PsU5iT8DGdcg7Kcso4/DDZeZkLKNeCKizkdMreF7qV0qHTW8z
> PyfZHcR/xWMkjxYZoFu4rVyxpsUJYItJNUNk6vZvSnSDfC2e2JJFfMws+fntNy14
> /w==
> -----END CERTIFICATE-----
> EOF
The certificate will be created for you. When you click the “Check authentication” button, you will be brought to this screen:
from which you can continue with normal LXD KVM setup.
How to use your own, existing certificate
Suppose that, after identifying your LXD KVM, you choose “Provide certificate and private key”. When you do so, the screen will extend to allow you to upload these items:
Paste or upload your certificate and private key, then click “Next” to validate your authentication criteria, before continuing through the normal LXD KVM creation process. If your certificate and/or key aren’t usable for some reason, MAAS will return an error (in this case, the private key was entered as gibberish, to produce an error output):
Upon selecting “Authenticate” (assuming successful authentication), you will receive a project selection screen similar to this:
You must either enter a new project name (which cannot contain spaces or special characters), or you must select an existing project. If you’re not really planning on using projects, selecting the “default” project will allow you to continue working as you have in the past.
If you want to add a libvirt or LXD VM host to a machine which is already installed, you can do so with the ‘Add KVM’ button:
Here, ‘Virsh address’ typically looks like the following for libvirt:
qemu+ssh://<vm host IP>/system
of like this for LXD (Beta):
https://10.0.0.100:8443
To add a VM host:
maas $PROFILE vm-host create type=$VM_HOST_TYPE power_address=$POWER_ADDRESS \
    [power_user=$USERNAME] power_pass=$PASSWORD {project=$PROJECT} \
    [zone=$ZONE] [tags=$TAG1,$TAG2,...]
$VM_HOST_TYPE can currently take two values: virsh and lxd.
$POWER_ADDRESS typically looks like the following for libvirt:
Both $USERNAME and $PASSWORD are optional for the virsh power type. $ZONE and $TAGS are optional for all VM hosts.
The power_... parameters will vary with power type. See the API reference for a listing of available power types.
For example, to create a LXD VM host, enter the following:
maas $PROFILE vm-hosts create type=lxd power_address=$LXD_BRIDGE_ADDRESS \
   power_pass=$LXD_TRUST_PASSWORD project=$PROJECT_NAME
Note that for LXD VM hosts, a project name is not optional. Project names cannot contain spaces or special characters. If you enter a project name which doesn’t exist, MAAS will create the LXD project for you.
To add a VM host:
$VM_HOST_TYPE can currently take three values: rsd, virsh, and lxd.
Some examples
For example, to create an RSD VM host, enter:
To create a KVM host, enter the following:
[/tabs]
MAAS will automatically discover and store the resources your VM host contains. Any existing machines will also appear on the ‘Machines’ page, and MAAS will automatically attempt to commission them.
How to configure a VM host
VM hosts have several configuration options. Modify these by selecting the ‘Configuration’ tab and editing options directly. These options include a VM host’s location, password, network zone, resource pool, and memory and CPU overcommit sliders.
Using the CLI, it’s possible to update the configuration of a VM host. You can change these configurable parameters with an update command – but first, you’ll want to know how to check the values of configurable parameters, both before and after the change.
How to list VM-hosts
To begin, you can list your available KVM-hosts with the following command:
maas admin vm-hosts read | jq -r '(["ID, "VM-HOST","SYSID","CORES",
"USED","RAM", "USED","STORAGE", "USED"] | (., map(length*"-"))),
(.[]| [.id,.name,.host.system_id,.total.cores, .used.cores, .total.memory, .used.memory,.total.local_storage, .used.local_storage])
| @tsv' | column -t
How to list configurable VM host parameters
There are just a few parameters that you can change for a VM host. You can list these, on a per-host basis, using the following two-step procedure:
  1. Run the command above to get the VM host ID (different from the System ID, see the first column in the listing).
  2. Enter the following command to list configurable parameters:
maas admin vm-host read $ID | jq -r '(["ID","NAME","POOL","ZONE",
"CPU-O/C", "RAM-O/C", "TAGS"] | (., map(length*"-"))), (.| [.id,.name,
.pool.name, .zone.name,.cpu_over_commit_ratio,
.memory_over_commit_ratio, .tags[]]) | @tsv' | column -t
where $ID is the ID (not System ID) of the VM-host.
How to change a VM host’s name
You can change the VM host’s name very simply, with this command:
maas admin vm-host update $ID name=$NEW_NAME
where $ID is the VM host’s ID (not System ID), and $NEW_NAME is the new name you want to assign. You can check that the change was successful by just printing out the ID and name, like this:
maas admin vm-host read $ID | jq -r '(["ID","NAME"]
| (., map(length*"-"))), (.| [.id,.name])
| @tsv' | column -t
How to change a VM host’s pool
You can also change the VM host’s pool with a simple command:
maas admin vm-host update $ID pool=$VALID_POOL
where $ID is the VM host’s ID (not System ID), and $VALID_POOL is the name of a pool that already exists. If you mention a pool you haven’t created yet, you’ll get an error like this:
{"pool": ["Select a valid choice. That choice is not one of the available choices."]}
maas admin resource-pools read | jq -r '.[] | (.name)'
If you really want to set your VM host to a new one, you just need to create a new one with this command:
maas admin resource-pools create name=$NEW_POOL_NAME
Then double-check it with catvmpools, and assign your VM host to it using the earlier command.
How to list the resources of all VM hosts
maas $PROFILE vm-hosts read
        "id": 93,
        "capabilities": [
            "composable",
            "fixed_local_storage",
            "iscsi_storage"
        "name": "civil-hermit",
How to list the resources of a single VM host
How to update a VM host’s configuration
How to list a VM host’s connection parameters
Example output:
    "power_pass": "admin",
    "power_user": "admin"
LXD clusters
MAAS 3.1 allows MAAS to take advantage of the existing LXD clustering capability.
About LXD clusters
LXD clusters within the context of MAAS are a way of viewing and managing existing VM host clusters and composing VMs within said cluster. MAAS will not create a new cluster, but will discover an existing cluster when you provide the info for adding a single clustered host.
How to add LXD clusters
MAAS assumes you have already configured a cluster within the context of LXD. You then need to configure said cluster with a single trust MAAS will use to communicate with said cluster. Adding a LXD cluster is similar to adding a single LXD host, in that you provide authentication the same way for a single host within the cluster, and then select a project. The only difference is the name you provide will be used for the cluster instead of the individual host. MAAS will then connect to the provided host and discover the other hosts within the cluster, and rename the initially defined host with the cluster member name configured in LXD.
First, add an LXD KVM:
Next, set up credentials and get your MAAS certificate trusted by LXD:
Once it is connected, you can select the project in that cluster:
If the KVM host address is part of a cluster, it will show as a Cluster on the listing page.
How to compose VMs in LXD clusters
Composing a VM in a LXD cluster via MAAS is similar to composing a VM for a single VM host. MAAS does not provide any sort of scheduling of said VM, and will instead target the host you select for composing the VM.
From the KVM host listing page, click on the + icon to add a VM to a specific host:
If you are in a specific KVM host page, you can click + add virtual machine:
How to delete LXD clusters
To delete a LXD cluster, delete any one VM host within the cluster, this will delete the cluster and all members within the cluster:
LXD clusters are available to MAAS starting with MAAS version 3.1.
[/tabs]
