How to use network tags (snap/2.9/UI)
This article will show you:
How to create and assign network interface tags
  1. Go to the machine list and select the machine where that interface resides, by clicking on that machine’s name:
  1. Click on the “Network” tab:
  1. Choose the interface you’d like to tag, by selecting the checkbox next to its name:
  1. Select the drop-down under “ACTIONS” at the end of the row, and select “Edit Physical” to edit the parameters of the physical interface:
  1. Edit the “Tags” field as desired.
  2. Be sure to select the “Tag machine” button to apply your changes to the interface for that machine.
How to remove and delete network interface tags
  1. Choose the interface you’d like to un-tag, by selecting the checkbox next to its name:
How to view network interface tags
  1. Choose the interface you’d like to see, by selecting the checkbox next to its name:
  1. Be sure to cancel the operation when you’re done.
