How to use network tags (deb/3.0/CL))
This article will show you:
How to discover the ID of your network interface
|@tsv'| column -t
For example:
|@tsv'| column -t
mac_address        type      id  tags
00:16:3e:18:7f:ee  physical  9   andrpko  plinko  cochise
How to assign tags to a network interface
For example:
How to remove tags from a network interface
For example:
How to list tags for all network interfaces
|@tsv'| column -t
For example:
|@tsv'| column -t
00:16:3e:18:7f:ee  physical  9   andrpko  plinko  cochise  farquar
How to view tags for one network interface
|@tsv'| column -t
For example:
|@tsv'| column -t
