This article will explain:
- How to assign machine tags to a machine
- How to remove machine tags from a machine
- How to list machine tags for all machines
- How to view machine tags for one machine
- How to discover your virtual machine host ID
- How to assign tags to a virtual machine host
- How to remove tags from a virtual machine host
- How to list tags for all virtual machine hosts
- How to view tags for one virtual machine host
For example:
"added": 1,
"removed": 0
| @tsv' | column -t
hostname sysid machine_tags
divine-stork 8b3ypp pod-console-logging virtual
casual-prawn 4end6r pod-console-logging virtual
driven-teal tgaat6 pod-console-logging virtual
immune-beetle 43xand pod-console-logging virtual
good-osprey napfxk pod-console-logging virtual
smart-hen c4rwq7 pod-console-logging virtual
boss-satyr xn8taa pod-console-logging androko
golden-martin 8fxery pod-console-logging virtual
crack-guinea qk4b3g pod-console-logging virtual
finer-leech cy3dtr pod-console-logging virtual
free-mouse gxtbq4 pod-console-logging virtual
humble-bunny srqnnb pod-console-logging virtual
wanted-muskox ekw7fh pod-console-logging virtual
one-boa by477d pod-console-logging virtual
great-urchin srnx4g pod-console-logging virtual
ace-frog g6arwg pod-console-logging virtual barbar farquar new_tag
alive-marlin gbwnfb pod-console-logging virtual
picked-parrot am77wn pod-console-logging virtual
tough-kit ke3wc7 pod-console-logging virtual
legal-whale 8nq3mt pod-console-logging virtual
game-sponge 76pdc6 pod-console-logging virtual
fun-ghoul qxfm7k pod-console-logging virtual
aware-earwig 8m8hs7 pod-console-logging virtual
chief-crane 7fapx7 pod-console-logging virtual
select-tapir 4ascbr pod-console-logging virtual
on-slug snfs8d pod-console-logging virtual
polite-llama dbqd4m pod-console-logging virtual
frank-coyote wcmk48 pod-console-logging virtual
usable-condor ed8hmy pod-console-logging virtual
still-imp h6ra6d pod-console-logging virtual
For example:
"added": 0,
"removed": 1
Adding and removing machine tags simultaneously from multiple machines
"added": 2,
"removed": 1
| @tsv' | column -t
golden-martin 8fxery pod-console-logging virtual barbar
one-boa by477d pod-console-logging virtual barbar
ace-frog g6arwg pod-console-logging virtual farquar
For example:
| @tsv' | column -t
For example:
| @tsv' | column -t
maas $PROFILE vmhosts read \
| @tsv' | column -t
For example:
maas admin vmhosts read \
| @tsv' | column -t
vm_host_name id
my-lxd-vm-host-1 1
maas $PROFILE vmhost add-tag $VMHOST_ID tag=$TAG_NAME
If it worked, this should return Success
, followed by the JSON that describes the VM host. You can check your work by listing all VM host tags.
For example:
vm_host_name id tags
my-lxd-vm-host-1 1 morkopongo pod-console-logging virtual
| @tsv' | column -t
name id tags
