Network discovery (snap/3.0/UI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
MAAS constantly listens to the network and reports any discovered devices. Devices are identified when the rack controller observes them communicating on an attached IPv4 subnet. Discovered devices that do not correspond to machines and devices already known to MAAS are shown on the dashboard. If a device advertises a hostname using mDNS (such as with avahi or Bonjour), MAAS will also present the discovered hostname in the Dashboard.
