MAAS requirements (snap/3.0/CLI)
Two questions you might have:
  1. What are the requirements for a test environment?
  2. What are the requirements for a production environment?
PostgreSQL 512 0.5 5
Rack controller 512 0.5 5
PostgreSQL 2048 2.0 20
Rack controller 2048 2.0 20
[note]
