How to mirror images locally (snap/3.0/UI)
Mirroring images is worthy of consideration. The SimpleStreams protocol delivers Images to MAAS, which is especially useful when your Internet link is slow or unreliable. In this mirrored configuration, images will be instantly available when MAAS requests them.
Six questions you may have:
  2. What is the stable stream?
  6. How do I set up a local image mirror?
Candidate stream
The candidate stream contains images and bootloaders which have not been explicitly tested with MAAS. Canonical’s automated build process dumps all images and bootloaders here before they are tested with MAAS. This stream is useful when testing a bug fix before an image or bootloader has been promoted to stable. Think of the candidate stream as a preview: it should never be used in a production environment; and users are encouraged to provide feedback on any issues they find with this stream.
Stable stream
Sunset of “daily” stream
Changing the stream - UI
Changing the stream - API/CLI
Setting up a local mirror
To use mirroring, you begin by installing the necessary software on the host that will house the mirror:
sudo apt install simplestreams
First define some variables to unclutter eventual CLI commands:
IMAGE_SRC=https://images.maas.io/ephemeral-v3/stable
IMAGE_DIR=/var/www/html/maas/images/ephemeral-v3/stable
The below example selects all available kernels that are compatible with either Ubuntu 18.04 (Bionic) and Ubuntu 20.04 (Focal) for the amd64 architecture, resulting in a download of approximately 3.1 GB. The second command mirrors the bootloaders.
sudo sstream-mirror --keyring=$KEYRING_FILE $IMAGE_SRC $IMAGE_DIR \
    'arch=amd64' 'release~(bionic|focal)' --max=1 --progress
    'os~(grub*|pxelinux)' --max=1 --progress
To know in advance what the sstream-mirror command will grab, or if you want to save bandwidth and time by avoiding bad selections, include the --dry-run option. When you are satisfied, remove that option to initiate the download.
MAAS will write the images to disk in the directory defined by the variable ‘IMAGE_DIR’ above, and the ‘location’ of the new boot source will be:
URL=http://<myserver>/maas/images/ephemeral-v3/stable/
Where <myserver> identifies your server’s hostname or IP address.
Verify the availability of the images by visiting the above URL.
The final sstream-mirror command should be invoked at regular intervals (i.e. with cron) to ensure the mirror contains the latest images.
Hi, I’m trying to set up local mirror following steps in this document.
I installed nginx and enabled autoindex and verified I can browse the URL. However when I try to add this custom source in “Images” tab, I get following error: "Error:No signature found! " I’ve been searching for any explanation what this error means and how to fix it but so far I found nothing. Can someone point me in the right direction? Thanks!
