IPv6 addressing (snap/3.0/CLI)
2.9 3.0
DEB CLI ~ UI CLI ~ UI
SNAP CLI ~ UI CLI ~ UI
Support for IPv6 in MAAS is similar to support for IPv4. A rack controller in an IPv6 context needs to have the region API server URL specified with brackets:
http://[::1]:5240/MAAS/
Three questions you may have:
Enable IPv6
Configure an IPv6 subnet
Define a reserved static IP range and machines deployed on the subnet will get a static address in this range. Since IPv6 networks usually are 64 bits wide you can be generous with the range size. Leave the netmask and broadcast address fields blank.
Routing
If you need RAs but your gateway does not send them, install and configure radvd somewhere on the network to advertise its route.
