How to enable high availability (deb/3.0/UI)
This page describes how to provide high availability (HA) for MAAS at both region and rack levels. In the context of MAAS, there are four types of HA:
  1. BMC (node power cycling)
  2. DHCP
  3. PostgreSQL
  4. API services
Nine questions you might have:
  1. How do I make rack controllers highly available?
  2. How do I enable highly-available BMC?
  3. How do I enable highly-available DHCP services?
  4. How do I make region controllers highly available?
  5. How do I enable highly-available PostgreSQL?
  6. How do I enable highly-available API services?
  7. How do I enable load balancing for API services?
  8. How do I move a rack controller from one MAAS instance to another?
  9. What are the potential dangers of moving a rack controller?
Enable highly-available BMC
Enable highly-available DHCP services
Access the appropriate VLAN (via the ‘Subnets’ page) and choose action ‘Reconfigure DHCP’. There, you will see the second rack controller in the ‘Secondary controller’ field. All you should have to do is press the ‘Reconfigure DHCP’ button:
To reconfigure DHCP after adding a new rack controller, use the following sequence of commands:
vid=$(maas maas subnets read | jq -r '.[] | select(.cidr == "10.0.0.0/24") | .vlan.vid')
fabric_name=$(maas maas subnets read | jq -r '.[] | select(.cidr == "10.0.0.0/24") | .vlan.fabric')
query=".[] | select(.name == \"$fabric_name\") | .id"
fabric_id=$(maas maas fabrics read | jq "$query")
maas maas ipranges create type=reserved start_ip=10.0.0.3 end_ip=10.0.0.49
maas maas ipranges create type=dynamic start_ip=10.0.0.50 end_ip=10.0.0.99
maas maas vlan update ${fabric_id} ${vid} primary_rack=$(hostname) dhcp_on=true
Be sure to substitute the sample values for those of your own environment.
MAAS will automatically discover and track all reachable region controllers in a single cluster of rack controllers It will also attempt to automatically connect to them if the one in use becomes inaccessible. Administrators can alternatively specify multiple region-controller endpoints for a single rack controller by adding entries to /etc/maas/rackd.conf. For example:
MAAS will automatically discover and track all reachable region controllers in a single cluster of rack controllers It will also attempt to automatically connect to them if the one in use becomes inaccessible. Administrators can alternatively specify multiple region-controller endpoints for a single rack controller by adding entries to /var/snap/maas/current/rackd.conf. For example:
maas_url:
  - http://<ip 1>:<port>/MAAS/
  - http://<ip 2>:<port>/MAAS/
  1. PostgreSQL HA
  2. Secondary API server(s)
MAAS stores all state information in the PostgreSQL database. It is therefore recommended to run it in HA mode. Configuring HA for PostgreSQL is external to MAAS. You will, therefore, need to study the PostgreSQL documentation and implement the variant of HA that makes you feel most comfortable.
Setting up high-availability using snaps is relatively easy:
  1. Set up PostgreSQL for high-availability as explained above. PostgreSQL should run outside of the snap.
  2. Install the MAAS snap on each machine you intend to use as a rack or region controller. You’ll need the MAAS shared secret, located here, /var/snap/maas/common/maas/secret, on the first region controller you set up.
  3. Initialise the snap as a rack or region controller. Note that if you intend to use a machine as a region controller, you’ll need to tell MAAS how to access your PostgreSQL database host with the following four arguments:
  4. --database-host DATABASE_HOST
  5. --database-name DATABASE_NAME
  6. --database-user DATABASE_USER
  7. --database-pass DATABASE_PASS
Please see Region controllers and Multiple region endpoints for more information about how to install and configure rack controllers for multiple region controllers.
You can add load balancing with HAProxy load-balancing software to support multiple API servers. In this setup, HAProxy provides access to the MAAS web UI and API.
Install
sudo apt install haproxy
Configure
frontend maas
    bind    *:80
    retries 3
    option  redispatch
    option  http-server-close
    default_backend maas
backend maas
    timeout server 90s
    balance source
    hash-type consistent
maas $PROFILE rack-controllers read
where the secret is found in /var/lib/maas/secret.
  • Connecting one instance of a rack controller to two instances of MAAS, regardless of version: Trying to connect a single rack controller to two different instances of MAAS can result in all sorts of unpredictable (and potentially catastrophic) behaviour. It is not a supported configuration.
