How to manage proxies (deb/2.9/UI)
  1. internal proxy (default)
  2. external proxy
  3. no proxy
Two questions you may have:
  1. How and why should I create an internal proxy?
  2. How and why should I create an external proxy?
Internal proxy (MAAS proxy)
MAAS manages its proxy. So although the active configuration, located in file /var/lib/maas/maas-proxy.conf, can be inspected, it is not to be hand-edited.
You must install the proxy on the same host as the region controller (via the ‘maas-proxy’ package).
Configuring an external proxy
In the web UI, visit the ‘Settings’ page and select the ‘Network services’ tab. The ‘Proxy’ section is at the top. You can apply your changes by pressing the ‘Save’ button.
To enable the internal proxy, ensure that the checkbox adjacent to ‘MAAS Built-in’ is selected. This internal proxy is the default configuration.
To enable an external proxy, activate the ‘External’ checkbox and use the new field that is displayed to define the proxy’s URL (and port if necessary).
An upstream cache peer can be defined by enabling the ‘Peer’ checkbox and entering the external proxy URL into the field. With this enabled, machines will be configured to use the MAAS built-in proxy to download cached APT packages.
To prevent MAAS machines from using a proxy, enable the ‘Don’t use a proxy’ checkbox.
