The region controller configures the NTP service to keep its time synchronised from one or more external sources. By default, the MAAS region controller uses ntp.ubuntu.com
. Rack controllers also configure the NTP service, synchronising their time with the region controllers. Rack controllers also configure DHCP with the correct NTP information. Any machine on the network that obtains a DHCP lease from MA/snap/3AS will benefit from NTP support.
You can specify an external site by choosing the NTP server(s) and selecting the ‘External Only’ option. The region controller always uses an external site.
On the ‘Settings’ page, select the ‘Network services’ tab and scroll down to the ‘NTP’ section:
Enter the address of the desired NTP server. Apply any changes by pressing the ‘Save’ button.
