How to manage IP ranges (deb/2.9/CLI)
Three questions you may have:
  1. How do I create an IP range?
  2. How do I edit an existing IP range?
  3. How do I delete an existing IP range?
Create a range
[tabs]
To create a range with the web UI, choose the “Subnets” option across the top:
In the “SUBNET” column, choose the subnet for which you want to create an IP range(s):
Scroll down to “Reserved ranges” on the subnet screen and click on the “Reserve range” drop-down:
Choose ‘Reserve range’ or ‘Reserve dynamic range’. If you choose the latter, MAAS will automatically provide DHCP for enlistment and commissioning provided that the associated VLAN has DHCP enabled.
Edit a range
Delete a range
To edit an IP range, first find the ID of the desired IP range with the command:
maas admin ipranges read
Examine the JSON output to find the ID corresponding to the IP range you want to edit, then enter:
maas admin iprange update $ID start_ip="<start ip>" end_ip="<end ip>" comment="freeform comment"
This command will update the IP range associated with $ID.
