How to test machines (deb/2.9/UI)
How to upload hardware test scripts
"history": [
        "id": 40,
        "comment": "Updated version"
        "id": 34,
        "comment": null
How to use tags to group commissioning and testing scripts
How to view testing results
"results": [
        "id": 21,
        "name": "smartctl-validate",
        "status": 5,
        "status_name": "Aborted",
        "exit_status": null,
        "runtime": "0:00:00",
        "endtime": 1554238601.765214,
        "parameters": {
            "storage": {
                "argument_format": "{path}",
                "type": "storage",
                "value": {
                    "id_path": "/dev/vda",
                    "model": "",
                    "name": "sda",
                    "physical_blockdevice_id": 1,
                    "serial": ""
        "script_id": 1,
        "script_revision_id": null,
        "suppressed": true
How to apply a hardware test
A default test will be selected (smartctl-validate, a hard drive test) but you can choose others by clicking the ‘Select scripts’ label. Doing so will reveal the following choices:
See Commissioning Scripts Reference for more details on how these scripts work and how you can write your own.
MAAS can check this link and recognise that there’s no connectivity, which alleviates hard-to-detect network issues:
