How to test machines (snap/2.9/CLI)
How to upload hardware test scripts
"history": [
        "id": 40,
        "comment": "Updated version"
        "id": 34,
        "comment": null
How to use tags to group commissioning and testing scripts
How to view testing results
"results": [
        "id": 21,
        "name": "smartctl-validate",
        "status": 5,
        "status_name": "Aborted",
        "exit_status": null,
        "runtime": "0:00:00",
        "endtime": 1554238601.765214,
        "parameters": {
            "storage": {
                "argument_format": "{path}",
                "type": "storage",
                "value": {
                    "id_path": "/dev/vda",
                    "model": "",
                    "name": "sda",
                    "physical_blockdevice_id": 1,
                    "serial": ""
        "script_id": 1,
        "script_revision_id": null,
        "suppressed": true
See Commissioning Scripts Reference for more details on how these scripts work and how you can write your own.
| @tsv' | column -t
| @tsv' | column -t
Administrators can change or update the link and interface speeds after manual changes
to the connection:
To test individual interfaces, for example, you could issue the following command:
