Replace $PROFILE with whatever username you set during the createadmin
part of the install process. Next, login with the following command:
Substitute $MAAS_URL with the URL that was returned to you when you initialised MAAS, for example, 192.168.43.251:5240/MAAS
. Remember that, once you’ve logged in, you can get extensive CLI help with the command:
maas admin --help
MAAS CLI help, sample output
usage: maas admin [-h] COMMAND ...
Issue commands to the MAAS region controller at http://192.168.43.251:5240/MAAS/api/2.0/.
optional arguments:
drill down:
COMMAND
boot-source-selection
boot-source-selections
commissioning-script
commissioning-scripts
dnsresource-records
TXT)
domain Manage domain.
domains Manage domains.
fabric Manage fabric.
fabrics Manage fabrics.
iprange Manage IP range.
ipranges Manage IP ranges.
interface Manage a node's or device's interface.
maas Manage the MAAS server.
network Manage a network.
networks Manage the networks.
node-script-results
MAAS.
package-repositories
MAAS.
pod Manage an individual pod.
Disks) on a machine.
MAAS.
sshkey Manage an SSH key.
MAAS.
sslkey Manage an SSL key.
space Manage space.
spaces Manage spaces.
subnet Manage subnet.
subnets Manage subnets.
nodes.
user Manage a user account.
zone Manage a physical zone.
zones Manage physical zones.
The command information you see here comes from the region server's
have changed, use the command's 'refresh' sub-command to fetch the
Configuration
- Setting upstream DNS
- Importing an SSH key for your admin user
- Importing images
- Configuring DNS
Setting DNS
Importing images
grub-efi-signed/uefi amd64/generic
grub-efi/uefi arm64/generic
pxelinux/pxe i386/generic
ubuntu/bionic amd64/ga-18.04
ubuntu/bionic amd64/ga-18.04-lowlatency
ubuntu/bionic amd64/hwe-18.04
ubuntu/bionic amd64/hwe-18.04-edge
ubuntu/bionic amd64/hwe-18.04-lowlatency
ubuntu/bionic amd64/hwe-18.04-lowlatency-edge
"os": "ubuntu",
"release": "trusty",
"arches": [
"amd64"
"subarches": [
"labels": [
"boot_source_id": 1,
"id": 2,
Enabling DHCP
"fabric_id": $FABRIC_ID,
$RACK_CONTR_HOSTNAME
"subnet": {
"name": "192.168.123.0/24",
"description": "",
"vlan": {
"vid": 0,
"mtu": 1500,
"dhcp_on": false,
"external_dhcp": null,
"relay_vlan": null,
"fabric": "fabric-2",
"primary_rack": null,
"name": "untagged",
"id": 5003,
"space": "undefined",
"secondary_rack": null,
"fabric_id": 2,
"cidr": "192.168.123.0/24",
"rdns_mode": 2,
"gateway_ip": null,
"dns_servers": [],
"allow_dns": true,
"allow_proxy": true,
"active_discovery": false,
"managed": true,
"id": 4,
"type": "dynamic",
"end_ip": "192.168.123.253",
"user": {
"is_superuser": true,
"username": "admin",
"email": "admin@admin.com",
"is_local": true,
"comment": "",
"id": 1,
"vid": 0,
"mtu": 1500,
"dhcp_on": true,
"relay_vlan": null,
"primary_rack": "8dwnne",
"name": "untagged",
"fabric_id": 2,
"id": 5003,
- subnet has the traditional meaning: a range of IP addresses covering a subset of IP addresses. Generally speaking , a subnet is a collection of IP addresses which includes at least two addresses.
- a space is a collection of subnets that you can create with MAAS, understanding that each subnet can belong to only one space. Spaces allow multiple subnets to communicate without requiring a direct network path between them.
- a zone is also an ad-hoc collection, but one which groups individual nodes, rather than subnets. MAAS allows you to create and edit zones at will.
- a fabric is essentially a collection of trunked switches, allowing you to access a group of VLANs.
VM hosts
