Configuration journey (snap/2.9/CLI)
maas admin --help
MAAS CLI help, sample output usage: maas admin [-h] COMMAND ...
Issue commands to the MAAS region controller at http://192.168.43.251:5240/MAAS/api/2.0/.
optional arguments:
drill down:
COMMAND
boot-source-selection
boot-source-selections
commissioning-script
commissioning-scripts
dnsresource-records
TXT)
domain Manage domain.
domains Manage domains.
fabric Manage fabric.
fabrics Manage fabrics.
iprange Manage IP range.
ipranges Manage IP ranges.
maas Manage the MAAS server.
network Manage a network.
networks Manage the networks.
node-script-results
MAAS.
package-repositories
MAAS.
pod Manage an individual pod.
Disks) on a machine.
MAAS.
sshkey Manage an SSH key.
MAAS.
sslkey Manage an SSL key.
space Manage space.
spaces Manage spaces.
subnet Manage subnet.
subnets Manage subnets.
nodes.
user Manage a user account.
zone Manage a physical zone.
zones Manage physical zones.
Configuration
  1. Setting upstream DNS
  2. Importing an SSH key for your admin user
  3. Importing images
  4. Configuring DNS
Setting DNS
Importing images
grub-efi-signed/uefi        amd64/generic
grub-efi/uefi           arm64/generic
pxelinux/pxe            i386/generic
ubuntu/bionic           amd64/ga-18.04
ubuntu/bionic           amd64/ga-18.04-lowlatency
ubuntu/bionic           amd64/hwe-18.04
ubuntu/bionic           amd64/hwe-18.04-edge
ubuntu/bionic           amd64/hwe-18.04-lowlatency
ubuntu/bionic           amd64/hwe-18.04-lowlatency-edge
    "os": "ubuntu",
    "release": "trusty",
    "arches": [
        "amd64"
    "subarches": [
    "labels": [
    "boot_source_id": 1,
    "id": 2,
Enabling DHCP
"fabric_id": $FABRIC_ID,
$RACK_CONTR_HOSTNAME
    "subnet": {
        "name": "192.168.123.0/24",
        "description": "",
        "vlan": {
            "vid": 0,
            "mtu": 1500,
            "dhcp_on": false,
            "external_dhcp": null,
            "relay_vlan": null,
            "fabric": "fabric-2",
            "primary_rack": null,
            "name": "untagged",
            "id": 5003,
            "space": "undefined",
            "secondary_rack": null,
            "fabric_id": 2,
        "cidr": "192.168.123.0/24",
        "rdns_mode": 2,
        "gateway_ip": null,
        "dns_servers": [],
        "allow_dns": true,
        "allow_proxy": true,
        "active_discovery": false,
        "managed": true,
        "id": 4,
    "type": "dynamic",
    "end_ip": "192.168.123.253",
    "user": {
        "is_superuser": true,
        "username": "admin",
        "email": "admin@admin.com",
        "is_local": true,
    "comment": "",
    "id": 1,
    "vid": 0,
    "mtu": 1500,
    "dhcp_on": true,
    "relay_vlan": null,
    "primary_rack": "8dwnne",
    "name": "untagged",
    "fabric_id": 2,
    "id": 5003,
VM hosts
