How to manage machine interfaces (snap/2.9/UI)
This article will explain the following procedures related to machine interfaces:
How to edit machines interfaces
From a machine’s “Interfaces” page, click the menu icon for the interface to be edited and select “Edit Physical” from the resulting menu:
The following window will appear:
Four modes determine how a subnet address is assigned when MAAS deploys the machine. You can select one of these modes by clicking on the “IP mode” drop-down menu.
  • Auto assign: MAAS will assign a random static address (iface eth0 inet static). The pool of available addresses depends on whether the subnet is managed or unmanaged (see Subnet management).
  • Static assign: The administrator will specify a static address using a secondary field.
  • DHCP: The machine leases a dynamic IP address, via either MAAS-managed DHCP or an external DHCP server.
  • Unconfigured: The interface is not configured.
Press the “Save” button to apply the changes.
For instance, to have interface 58, with subnet link 146, on machine exqn37 use DHCP on subnet 192.168.1.0/24:
How to create a bond interface
A bond is created by selecting more than one interface and clicking the now-active “Create bond” button:
After clicking the “Create bond” button, the bond configuration pane will appear.
From the bond configuration pane, you can rename the bond, select a bond mode (see below), assign a MAC address to the aggregate device and attach one or more tags.
The interfaces aggregated into the bond interface are listed below the “Tags” field. Use the “Primary” column to select the interface to act as the primary device.
You can select from the following bonding modes on the “Bond mode” drop-down menu:
  • balance-rr: Transmit packets in sequential order from the first available slave through to the last. This mode provides load balancing and fault tolerance.
  • active-backup: Only one slave in the bond is active. A different slave becomes active if, and only if, the active slave fails. The bond’s MAC address is externally visible on only one port (network adaptor) to avoid confusing the switch.
  • balance-xor: Transmit based on the selected transmit hash policy. The default policy is simple, which means that an XOR operation selects packages. This XOR compares the source MAC address and the resultant XOR between the destination MAC address, the packet type identifier, and the modulo slave count.
  • broadcast: Transmit everything on all slave interfaces. This mode provides fault tolerance.
  • 802.3ad: Creates aggregation groups that share the same speed and duplex settings. This mode utilises all slaves in the active aggregation, following the IEEE 802.3ad specification.
  • balance-tlb: Adaptive transmit load balancing, channel bonding that does not require any special switch support.
  • balance-alb: Adaptive load balancing, includes balance-tlb plus receive load balancing (rlb) for IPV4 traffic. This mode does not require any special switch support. ARP negotiation achieves load balancing in this case.
Press the “Save” button when you’re done.
The MAC address defaults to the MAC address of the primary interface.
A bond can be created with the following command:
Use the parents parameters to define which interfaces form the aggregate interface.
The bond_updelay and bond_downdelay parameters specify the number of milliseconds to wait before either enabling or disabling a slave after a failure has been detected.
The following is an example of create-bond in action:
There are a wide range of bond parameters you can choose when creating a bond:
Parameter Type and description
mac_address Optional string. MAC address of the interface.
tags Optional string. Tags for the interface.
vlan Optional string. VLAN the interface is connected to. If not provided then the interface is considered disconnected.
parents Required integer. Parent interface ids that make this bond.
bond_miimon Optional integer. The link monitoring frequency in milliseconds. (Default: 100).
bond_downdelay Optional integer. Specifies the time, in milliseconds, to wait before disabling a slave after a link failure has been detected.
bond_updelay Optional integer. Specifies the time, in milliseconds, to wait before enabling a slave after a link recovery has been detected.
bond_lacp_rate Optional string. Option specifying the rate at which to ask the link partner to transmit LACPDU packets in 802.3ad mode. Available options are fast or slow. (Default: slow).
bond_xmit_hash_policy Optional string. The transmit hash policy to use for slave selection in balance-xor, 802.3ad, and tlb modes. Possible values are: layer2, layer2+3, layer3+4, encap2+3, encap3+4. (Default: layer2)
bond_num_grat_arp Optional integer. The number of peer notifications (IPv4 ARP or IPv6 Neighbour Advertisements) to be issued after a failover. (Default: 1)
mtu Optional integer. Maximum transmission unit.
accept_ra Optional Boolean. Accept router advertisements. (IPv6 only)
autoconf Optional Boolean. Perform stateless autoconfiguration. (IPv6 only)
bond_mode Optional string. The operating mode of the bond. (Default: active-backup).
Supported bonding modes include:
Mode Behaviour
balance-rr: Transmit packets in sequential order from the first available slave through the last. This mode provides load balancing and fault tolerance.
active-backup Only one slave in the bond is active. A different slave becomes active if, and only if, the active slave fails. The bond’s MAC address is externally visible on only one port (network adaptor) to avoid confusing the switch.
balance-xor Transmit based on the selected transmit hash policy. The default policy is a simple [(source MAC address XOR’d with destination MAC address XOR packet type ID) modulo slave count].
broadcast Transmits everything on all slave interfaces. This mode provides fault tolerance.
802.3ad IEEE 802.3ad dynamic link aggregation. Creates aggregation groups that share the same speed and duplex settings. Uses all slaves in the active aggregator according to the 802.3ad specification.
balance-tlb Adaptive transmit load balancing: channel bonding that does not require any special switch support.
balance-alb Adaptive load balancing: includes balance-tlb plus receive load balancing (rlb) for IPV4 traffic, and does not require any special switch support. The receive load balancing is achieved by ARP negotiation.
How to create a bridge interface
Please use the UI interface to create a bridge interface. Select the “UI” dropdown above to see how.
How to delete an interface
An interface can only be deleted via the MAAS CLI. Choose the “CLI” dropdown above to see how.
parent=$IFACE_ID
Use parent to define the primary interface used for the bridge:
The following parameters may be applied when creating a bridge:
  1. name: Optional string. Name of the interface.
  2. mac_address: Optional string. MAC address of the interface.
  3. tags: Optional string. Tags for the interface.
  4. vlan: Optional string. VLAN the interface is connected to.
  5. parent: Optional integer. Parent interface id for this bridge interface.
  6. bridge_type: Optional string. The type of bridge to create. Possible values are: standard, ovs.
  7. bridge_stp: Optional Boolean. Turn spanning tree protocol on or off. (Default: False).
  8. bridge_fd: Optional integer. Set bridge forward delay to time seconds. (Default: 15).
  9. mtu: Optional integer. Maximum transmission unit.
  10. accept_ra: Optional Boolean. Accept router advertisements. (IPv6 only)
  11. autoconf: Optional Boolean. Perform stateless autoconfiguration. (IPv6 only)
The “delete” command can be used to delete a bridge interface, a bond interface or a physical interface:
For example:
Note that while the label is presented, there is no machine-readable output expected after the successful execution of the delete command.
How to assign a network interface to a fabric
A network interface may be assigned to a fabric with the MAAS CLI only. Choose the “CLI” dropdown above to see how.
sudo apt install jq
Example output:
Example output:
Example output:
How to discover interface identifiers
Interface identifiers can only be discovered via the MAAS CLI. Choose the “CLI” dropdown above to see how.
"id": 15,
"name": "ens9",
How to create a VLAN interface
VLAN interfaces can only be created via the MAAS CLI. Select the “CLI” dropdown above to see how.
    "vid": 100,
    "mtu": 1500,
    "dhcp_on": false,
    "external_dhcp": null,
    "relay_vlan": null,
    "name": "Storage network",
    "space": "undefined",
    "fabric": "fabric-0",
    "id": 5004,
    "primary_rack": null,
    "fabric_id": 0,
    "secondary_rack": null,
parent=$IFACE_ID
    "tags": [],
    "type": "vlan",
    "enabled": true,
    "system_id": "4efwb4",
    "id": 21,
    "children": [],
    "params": {},
    "vlan": {
        "vid": 100,
        "mtu": 1500,
        "dhcp_on": false,
        "relay_vlan": null,
        "id": 5004,
        "fabric_id": 0,
    "parents": [
        "ens3"
    "effective_mtu": 1500,
    "links": [
            "id": 55,
            "mode": "link_up"
    "discovered": null,
    "name": "ens3.100",
[/tabs]
How to delete a VLAN interface
VLAN interfaces can only be deleted via the MAAS CLI. Select the “CLI” dropdown above to see how.
maas admin vlan delete 0 100
