How to manage availability zones (snap/2.9/CLI)
Six questions you may have:
  1. How do I list availability zones?
  2. How do I add an availability zone?
  3. How do I edit an existing availability zone?
  4. How do I delete an existing availability zone?
  5. How do I assign a machine to an availability zone?
  6. How do I allocate a machine in a particular zone?
List availability zones
To see a list of availability zones, enter the following command:
maas $PROFILE zones read \
| jq -r '(["ZONE","NAME","DESCRIPTION"]
| (., map(length*"-"))), (.[] | [.id, .name, .description])
| @tsv' | column -t
which produces output similar to:
ZONE  NAME         DESCRIPTION
5     BizOffice
1     default
4     Inventory
2     Medications
3     Payroll
6     ProServ
Add a zone
To create a zone, enter the following command:
maas $PROFILE zones create name=$ZONE_NAME description=$ZONE_DESCRIPTION
Edit a zone
To edit a zone, enter a command similar to the following:
maas $PROFILE zone update $OLD_ZONE_NAME name=$NEW_ZONE_NAME \
Delete a zone
To delete a zone, enter a command like this:
maas $PROFILE zone delete $ZONE_NAME
Assign a machine to a zone
To assign a machine to a zone, first retrieve the machine’s system ID like this:
maas PROFILE machines read | jq '.[] | .hostname, .system_id'
Then enter the following command, using the system ID you just retrieved:
maas admin machine update $SYSTEM_ID zone=$ZONE_NAME
Allocate a machine in a zone
Allocating a machine in a particular zone can only be done via the MAAS CLI.
To deploy in a particular zone, call the acquire method in the region-controller API <region-controller-api> as before, but pass the zone parameter with the name of the zone. This method will allocate a machine in that zone, or fail with an HTTP 409 (“conflict”) error if the zone has no machines available that match your request.
Alternatively, you may want to request a machine that is not in a particular zone or one that is not in any of several zones. To do that, specify the not_in_zone parameter to acquire. This parameter takes a list of zone names; the allocated machine will not be in any of them. Again, if that leaves no machines available that match your request, the call will return a “conflict” error.
It is possible, though not usually useful, to combine the zone and not_in_zone parameters. If your choice for zone is also present in not_in_zone, no machine will ever match your request. Or if it’s not, then the not_in_zone values will not affect the result of the call at all.
