About MAAS (deb/2.9/UI)
Questions you may have:
  1. What is MAAS?
  2. What does MAAS offer me?
  3. Can MAAS co-locate key components to conserve resources?
  4. How does MAAS work?
What is MAAS?
Tell me about PXE booting
What MAAS offers
MAAS also discovers all of the USB and PCI devices attached to your physical or virtual machines, and allows you to delete them from the machine’s visible configuration, prior to deployment, if you so desire.
MAAS 2.9 does not discover USB and PCI devices. For this discovery capability, you must upgrade to MAAS version 3.0 or greater.
  1. web UI (optimised for mobile devices)
  2. Ubuntu, CentOS, Windows, and RHEL installation support
  3. open-source IP address management (IPAM)
  4. full API/CLI support
  5. high availability (optional)
  6. IPv6 support
  7. inventory of components
  8. DHCP and DNS for other devices on the network
  9. DHCP relay integration
  10. VLAN and fabric support
  11. NTP for the entire infrastructure
  12. hardware testing
  13. composable hardware support
MAAS integrates all the tools you need into a smooth system-management experience. It includes the following eleven features:
  1. Ubuntu, CentOS, Windows, and RHEL installation support
  2. open-source IP address management (IPAM)
  3. high availability (optional)
  4. IPv6 support
  5. inventory of components
  6. DHCP and DNS for other devices on the network
  7. DHCP relay integration
  8. VLAN and fabric support
  9. NTP for the entire infrastructure
  10. hardware testing
  11. composable hardware support
Colocation of key components
How MAAS works
When acquiring machines from the API/CLI, you can specify requirements (“constraints”). Common constraints are memory, CPU cores, connected networks, and assigned physical zone.
