MAAS logging
MAAS has a robust logging capability, which presents several different views, including a number of node-specific log files, and several syslogd-style text logs. Each of these logs provides different information, or at the very least, different views of the same information. MAAS gathers logging information the various MAAS states and records both automated and user-driven actions.
The syslog logging path
Syslog data is kept in /var/log/maas/rsyslog/<machine-name><yyyy-mm-dd>/messages (/var/snap/maas/common/log/rsyslog/<machine-name><yyyy-mm-dd>/messages when using the snap). Every machine known to MAAS will have corresponding syslogs.
Using a remote syslog server
See MAAS CLI to learn how to add a remote syslog server using the CLI.
I was migrating over from deb to snap and I was looking where to find the internal MAAS logs. It might be worth specifying this location (/var/snap/maas/common/log/) even though it is more a snap thing.
P.S I am sure you are aware, but the What is the syslog logging path? link/page is broken with a 404.
@szeestraten, thanks for the tip on the logging page. Looks like a draft version with protected links got posted on the public side. No difference in content, just mistakenly posted a draft. Should be fixed now, let me know if it isn’t.
